Go Back   Tremek Car Videos - Street Car Drag Racing Videos > Car Tech Section > General Automotive Talk
Corvette ZR-1 revealed Dec 20th 12:01 a.m.
Old 19 Dec 2007, 11:01 pm   #46 (permalink)
User is rowing away
bmxer99's Avatar
Default Re: Corvette ZR-1 revealed Dec 20th 12:01 a.m.
anahahahahaha ****ing memphis lol
bmxer99 is offline
Old 19 Dec 2007, 11:18 pm   #47 (permalink)
Cylinder block and reciprocating assembly details
The LS9’s aluminum cylinder block features steel, six-bolt main bearing caps, with enlarged vent windows in the second and third bulkheads for enhanced bay to bay breathing. Cast iron cylinder liners – measuring 4.06 inches (103.25 mm) in bore diameter – are inserted in the aluminum block and they are finish-bored and honed with a deck plate installed. The deck plate simulates the pressure and minute dimensional variances applied to the block when the cylinder heads are installed, ensuring a higher degree of accuracy that promotes maximum cylinder head sealing, piston ring fit and overall engine performance.
Nestled inside the cylinder block is a forged steel crankshaft that delivers the LS9’s 3.62-inch (92 mm) stroke. It features a smaller-diameter ignition-triggering reluctor wheel and a nine-bolt flange – the outer face of the crankshaft on which the flywheel is mounted – that provides more clamping strength. Other non-supercharged 6.2L engines, such as the base Corvette’s LS3, have a six-bolt flange. A torsional damper mounted to the front of the crankshaft features a keyway and friction washer, which also is designed to support the engine’s high loads.
Attached to the crankshaft is a set of titanium connecting rods and forged aluminum pistons, which, when combined with the cylinder heads, delivers a 9.1:1 compression ratio. This combination is extremely durable and lightweight, enabling the LS9’s high-rpm capability.
800hp on stock internals?
the worst thing you could do is panic
use it to your advantage
avoid insanity manage to conquer
every obstacle
make impossible possible
even when winnings illogical
memphis once owned a dsm, but he said fuk the bs and invented the LSx
Old 19 Dec 2007, 11:23 pm   #48 (permalink)
User is rowing away
bmxer99's Avatar
shit 12.5 qts of oil
bmxer99 is offline
Old 21 Dec 2007, 10:03 am   #49 (permalink)
I don't think the added 250lbs is a big deal, when you factor in additional 115hp. Supercharger/ intercooler, additional fluids and re-balancing the car are all new weight factors.
The weight of the car is now the same as a 911 turbo, Viper etc and supercharged hp is > N/A HP. The ZR1 is going to pick up huge average HP gains throughout its insane 6600 RPM redline.
Can't wait until they test it, hopefully it will be tested against the 09 Skyline, and the BLUE colour looks amazing, in my opinion.
05BLKSTANG is offline
Old 21 Dec 2007, 10:15 am   #50 (permalink)
Oh yah almost forgot to say, i'm suprised they are using a Roots style supercharger than a twin screw for example. Yes it's a bit more expensive, but overall it's not going to make a huge differance.
Lastly, dont you think an ultimate road test would be
ZR1 vs Skyline vs Super Snake?
Old 21 Dec 2007, 01:37 pm   #51 (permalink)
Look at the torque on this mofo
every obstacle
2007 Jay Leno E85 Chevrolet Corvette static Car Pictures 23 27 Nov 2007 05:54 pm
Mercedes SLR VS 630HP Corvette Z06 C6 trev0006 Mercedes Videos 4 12 Nov 2007 07:58 am
BMW M6 vs Stock 2007 Corvette C6 ZO6 UKunt GM Videos 26 18 Oct 2007 04:31 pm
Initial-D 2 BizzarBoxer General Car Videos 89 10 Sep 2006 09:26 am
Skyline vs. Corvette GTRJack Nissan Videos 1 28 Sep 2005 06:57 pm
