i like to use the supra with super soft tires on front and hard on the rear.There are more options but try this first.The only way to find what you are comfortable with is to fu.ck with your suspension alot.
Bombs to set the people free,Blood to feed the dollar tree,Flags for coffins on the screen,Oil for the machine.Army of liberation,Gunpoint indoctrination,The fires of sedition fulfill the prophecy. |
make sure your TCS is off and your Asm is on like 3.
there's lots of them such as:
suspension: addmore camber on the front than the rear, I do it at Front: 3 Rear: 1.5. Little power = softer suspension or High power= Stiffer suspension. Bound: between 2-6 (makes faint drifting easier) Downforce: Make sure you have a wing, it will allow you for better controlled drifts. Downforce either: all the way up, F + R the same or Higher on the Rear than the front. This will prevent spin outs. Driving Aids: SC = 0 Steering Aid = 20 TC = 1 (unless you use racing tires). tires/LSD: If you wanna use cheap tires and lots of power, then get an LSD (limited slip differential) and set it all the way up for torque during acceleration (2nd one down the row)... If you wanna use racing tires you might wanna lower the (LSD) torque during acceleration/deacceleration... there's a couple more, but it's up to the driving ability... :thumpup: |
i use the cheapest tires i could get for both front AND rear. i set my tcs and asm both at 0. i give the car a little more camber in the front, i keep the spring rates soft, i increase teh stuff for differential.. n i just hit it. i guess some of u guys might be looking at my asm at 0 but im used to it.. its soo much easier to get loose..
Sri Lankan to the fullest. 67' MG Midget 70' MG Midget.... Pure Hotness... Coming Soon |
yeah but i think it is alot more fun to fully beef up the settings.
