lmao....one of the funniest yet. we need slow mo on that.
hahaha, he was airbourn
![]() K&N filter with modified lid, 52mm TB, ported plenum, Edelbrock High Flo runners, Stock baseplate, ported aluminum heads, Custom grind camshaft by DRM, Roller rockers at 1.5, High flow stainless valves, high perf springs, chrome moly rods, high volume fuel pump, adjustable fuel pressure regulator, MSD ignition, LT ceramic coated headers, full stainless exhaust out straight pipes, stock 2:73 gears in D36. also Edelbrock valve covers, chrome break reservoir, 18" black ZR1s on Nitto 555s 275/40 |
Location: In a town with too many old people & some prick that punched me in the back of the head!
I call totally acted, if anything got hurt it wasn't his nuts cause the last position you want to be in when they get hit is lying on your back with legs out - it stretches your gut too much, blokes only ever bend over into a ball cause of the pain..
Frisbeeism - (n) A religion based around the belief that upon death, the soul rises out of the body and gets stuck on the nearest roof.
