Go Back   Tremek Car Videos - Street Car Drag Racing Videos > Car Videos > Ford Videos
Stock Block 302 + 20psi = this
Old 20 Mar 2004, 11:29 am   #1 (permalink)
Administrator
skylight's Avatar
Default Stock Block 302 + 20psi = this
10.32 @ 138 mph
The car in question is a '93 Cobra, out of the box Edelbrock Performer heads, Cobra intake (lower matched to Edelbrock runners) and a B-303 cam. The short block is stock with the exception of ARP bolts, stock displacement, crank, rods, etc.
On a run with ~20psi of boost, they had to let off at 4500rpms as the boost was climbing a little too high. The car still put down
630rwhp@4500
784rwtq@4100
The torque had peaked at 4100rpms but the horsepower was still climbing!! These are actual numbers at sea level, no correction factoring.
They turned the boost down to a more street-friendly level and it peaked at 15psi but was bleeding down to 13psi (need a different boost controller) and the car made
572rwhp@4600
708rwtq@4000
Again, this is on the stock bottom end (with ARPs), the car has stock electronics with a C&L MAF, 42lb injectors and a 1:1 regulator. The turbo is the stock 60mm that comes base with their kit. Tranny is a World Class T-5 with a SPEC Stage III clutch, tires are 28x10.5 ET Drags with 3.73 gears. The power curves are as flat as Kansas, Jimmy will post the dyno sheets tomorrow
Video:
http://www.turbochargedpower.com/Movies/Cobra%20Run.avi
10.32 @ 138 mph
Right Click on the Video links "SAVE AS" OR "SAVE TARGET AS" To save to your Hard
PT Cruiser Forum | Honda Prelude Forum | Subaru Impreza Forum | Quarrel Forum
PSP Videos | Arcade Games | Browser Games | RSS Directory
MediWar | GiroPets
skylight is offline
Old 20 Mar 2004, 01:26 pm   #2 (permalink)
my only question is where this kit is offered from?
RICO BRICKINGTON
Traction Issuez is offline
Old 20 Mar 2004, 02:13 pm   #3 (permalink)
Administrator
skylight's Avatar
Kits are for kids
MediWar | GiroPets
skylight is offline
Old 20 Mar 2004, 03:21 pm   #4 (permalink)
no trix are for kids, well thats what they told the rabbit on TV.
RICO BRICKINGTON
