Go Back   Tremek Car Videos - Street Car Drag Racing Videos > Car Videos > Audi Videos
Guys Need Help
View Poll Results: Audi S4 Biturbo or BMW M3 Both 2001?
BMW M3? 8 50.00%
Audi S4? 8 50.00%
Multiple Choice Poll. Voters: 16. You may not vote on this poll
Old 18 May 2005, 05:41 pm   #1 (permalink)
AudiS4B5biturbo's Avatar
Send a message via AIM to AudiS4B5biturbo
Default Guys Need Help + Videos
Hey does anyone know where to get the Audi OOOO vylans the large ones that go from before the back tired to the trunk?
Old Audi Quattro
AudiS4B5biturbo is offline
Old 18 May 2005, 05:44 pm   #2 (permalink)
Default Niiice
Oh ya old audi quattro is not my car just a video i ran into
Supra Vs. Audi S4 Avant <AVANT!!! :banghead:
WRX STI Vs. S4 <WRX HA
Older Audi S4 Vs. Golf VR-6
Old 18 May 2005, 10:39 pm   #3 (permalink)
Frog eater modo
Blackmilk's Avatar
Access Denied
You cannot access the content "Audi Quattro 4x4 burnout (1).mpg".
We're all gonna be like Fonzie in here
Blackmilk is offline
Old 18 May 2005, 11:16 pm   #4 (permalink)
Verrückt's Avatar
Originally Posted by AudiS4B5biturbo
Hey everyone just started you will be hearing allot from me i just turned into an audi fan after test driver one of the new rs4's a friend bought, ****ING SICK CARS Anyways i sold my Prelude and saved up money and bought a Audi S4 the 2001 Biturbo's i love it but i bought it stock and just have two Type S BOV's and just wondering what the first best thing to do is, i have heard already the ECU chips from IITek are sick and add a good 80 Hp and a Boost Controller would be good just up a few PSI but was worried about blowing head gasket im not to sure like i said i just started in the audi crowd, so any input?
Old Audi Quattro Doing Dounuts
-The first thing you should do is take off the stupid BOV's.
-If you want a chip, get a GIAC. It has the most power and torque. The chip regulates the boost, you really don't need a boost controller in most cases.
-You don't need to worry about the head gasket on the stock turbos, up to almost 30 psi isn't a problem.
Verrückt is offline
Old 19 May 2005, 09:17 am   #5 (permalink)
Aww i take it u dont like BOV's? Sad
So chip yes, boost controller no, and 30 psi Per Turbo or 15 Per turbo? Probably 15 since the stock turbos run 14 PSI together huh?
S4.....Biturbo..... Lucky
Old 20 May 2005, 12:02 am   #6 (permalink)
Verrückt's Avatar
I don't like BOV's and they will make your car perform worse than stock. BOV's don't work well on cars with pull though MAF sensors.
Get some Bosch 710N diverter valves, they will perform much better and are cheaper.
You don't "add" boost pressures. Both turbos will provide about the same overall boost pressure but the flow rates are added. If you have 15 psi of manifold boost, both turbos are making approximately 15 psi.
I wouldn't go over 18 psi midrange and 14 psi at redline with the stock turbos. If you do, they won't last very long.
I think you need to learn a little more about turbos and how this engine works.
Verrückt is offline
Old 20 May 2005, 12:05 pm   #7 (permalink)
OH yay thanks man thats the kind of info i need :thumpup:
Old 21 May 2005, 05:16 pm   #8 (permalink)
Well what does a diverter valve accomplish that is so much better then a blow off valve?
And if u dont add Boost then what is the need for a boost controller itself? So if i add a boost controler to my s4 there is no way to up the PSI?
Old 22 May 2005, 04:07 am   #9 (permalink)
Verrückt's Avatar
The diverter valve recirculates the air through to the intake manifold. This means that you don't lose air to the atmosphere. A blowoff valve vents all the air to the atmosphere. This confuses the car's MAF and ECU system and will cause you to run rich. The car is designed to run with a diverter valve and you will have the best performance if you keep them.
If you add an MBC, you will not be able to raise the boost. You will only go into limp mode and the computer will get pissy with you.
There is no need for a boost controller. When you get a chip, this raises the boost automatically.
Verrückt is offline
Old 22 May 2005, 05:01 pm   #10 (permalink)
... and knowing is half of the battle.
Big Smoke is offline
Old 24 May 2005, 03:47 pm   #11 (permalink)
Default forums
howdy brethren. you can probably get more answers at www.Audiworld.com. Good bunch of people over there...gl!
chekm8 is offline
Old 25 May 2005, 03:05 pm   #12 (permalink)
Send a message via AIM to Still_Good
You can, alternatively, get recirculation fittings for most BOVs.
I have an HKS SSQV that is not going on my galant until I get off my lazy ass and get the recirc fitting/pipe.
Galant VR4 92/2000.
This thing breaks as much as a DSM
Oh shit, it is a DSM
Still_Good is offline
Old 26 May 2005, 06:42 pm   #13 (permalink)
oh where could i get those at and um... lol does it still make the blow off valve sound, PSHHH PSHHHH lol i love that part, the main reason i get them
Old 27 May 2005, 12:58 pm   #14 (permalink)
Send a message via ICQ to Pisca Send a message via MSN to Pisca
Well...the Supra only get close when it shifts the 4º gear...jap crap! If this Audi was a litlle bit tunep up... :loser1:
Pq um dedo é benga!
Pisca is offline
Old 29 May 2005, 07:40 am   #15 (permalink)
A recirculating dump valve doesnt make a sound. I wouldnt bother getting a dump valve. Personaly i much prefer the sound of the actuator fluttering. Im not farmiliar with the audi engine so someone else might be able to tell u how to get that loud actuator flutter sound. With my old car it used to be a case of just putting a cone filter on and a large turbo.
G_R5GTT is offline
